1 reakcí na tento příspěvek Kontrolka servis
2 reakcí na tento příspěvek Kontrolka servis
2004 Aprilia RSVR and RSVR Factory
Resetting the service light
2004 RSV1000R, RSV1000 Factory Siemans/VDO Fuel Injection
1. Turn the ignition key on.
2. Depress and Hold the + and buttons for at least 15 seconds
3. Turn off the ignition key.
1. Remove the seat.
2. On the right hand side (as you face the bars) near the battery you will find two connectors. One each, male and female. The female connector has two grey wires and the male has a blue/green wire. Connecting these two together puts the onboard computer into diagnostic mode. Connect these together, noting their original position for later.
3. Turn on the ignition (don't start the engine).
4. On the right hand instrument panel, "EFI" will now display above the MODE button.
5. Press and hold the MODE button.
6. While still pressing the MODE button, press and hold the SET button.
7. Keep both buttons pressed until the "Service" indicator disappears (seems like a long time, 10+ seconds).
8. Turn off the ignition.
9. Disconnect the diagnostic connectors and place them in their original position.
10. Turn ignition back on to verify "SERVICE" indicator is out and panel displays normally.
11. Replace seat and ride safely.
1) Nejlepe nejakou vidli zmacknes tlacitka + a - ( - dost casto blbne) a drzet cca 20 s pri vypnutem zapalovani
2) porad drzis a zapnes zapalovani a cekas dalsich 20 s
3) porad drzis a vypnes zapalovani a cekas 20 s
4) porad drzis a zapnes zapalovani cca po 20 s hlaska SERVICE zmizi, reset je kompletni
Co kdyz to ted zkusmo vyresetuji a olej servis provedu az pozdeji. Bude tento dvouhmat fungovat ikdyz nesviti napis service?
Nebo opacne. Tohle byl blvej priklad. Zas by nekdo slovickaril a misto aby resil dotaz
Udelam po zime servis. Ale ten napis zatim jeste nesvitil. jak vynuluji interval, aby mi za par tis km nevyskocil?
Da se i menit jeho hodnota?
Aprilia RSV úpravy a tuning [1 ... 208, 209] Aprilia RSV 1000 | WenCa | 6248 | 28.2.2024 v 16:15 doveda |
nestartujicí RSV 1000 s Rotaxem Aprilia RSV 1000, Aprilia RSV 1000 R, Aprilia RSV 10... | kokoška. | 19 | 1.1.2024 v 16:56 kokoška. |
Zapojení power commander 3 Aprilia RSV 1000 | lukasst | 9 | 22.10.2023 v 00:53 zdenyrr |
Metzeler Sportec M9RR zkusenosti Aprilia RSV 1000 | Supermotojunkie | 15 | 29.12.2022 v 17:29 assassin |
Conti road attack 4 vs pirelli ange... Aprilia RSV 1000 | Supermotojunkie | 13 | 15.7.2022 v 16:52 Supermotojunkie |
