EDIT : ted si jeste ctu znova ten navod a tam pisou "Charging the connected battery directly at the battery terminals can damage the motorcycle electronics." a kousek vedle "Only charge connected battery via onboard socket.". Takze nesmim nabijet primo z konektoru u baterky ale muzu z tech vyvedenejch bokem ?
Díky a jízdě zdar
Naposledy editováno 13.12.2015 11:32:50
