Téma: tl 100 Tre timing retard eliminator
28.10.2014 v 10:53
Neví někdo kde se dá tohle sehnat a co to vůbec je?
28.10.2014 v 11:07 | Nahoru | #1
Jsi očividně dost inteligentní jedinec, tak ti to hodím v originálu:
AUTOMATIC
TIMING RETARD
ELIMINATOR
A LITTLE BACKGROUND INFO ON THE TRE...
The TRE is a device that allows better throttle response
in the first four gears on all of Suzuki's EFI sportbikes.
What Suzuki did was make a SEPARATE ignition map
for each gear. This has been done for safety &/or
emissions reasons... However, it limits the power
& smoothness of your bike in the first 1/2 turn
of the throttle in gears 1 through 4.
They were clever in the design of this timing retarder:
it still allows full timing at full throttle. As you shift up
through the gears, the amount of throttle needed to
access the advanced curve decreases, until you get to
5th: then it's gone. You have nice, smooth operation.
Wouldn't you like your bike to respond
just as smoothly in the lower gears?
TRE WILL SMOOTHE OUT THE SNATCHY ON/OFF THROTTLE.
POWER DELIVERY IS SMOOTH & MORE
USABLE, ESPECIALLY UNDER 4500RPM.
IT WILL ALSO DISABLE THE TOP SPEED LIMITER.
SO WHAT's THE DIFFERENCE BETWEEN A
STANDARD TRE & THE AUTOMATIC TRE??
The Automatic TRE has a built-in computer chip,
and requires no adjustments to idle speed or
fuel mixture to maintain smooth idle quality!
100% compatible with Power Commanders.
THIS UNIT WILL CHANGE HOW YOUR MOTORCYCLE BEHAVES.
TAKE TIME TO GET USED TO THE ADDED THROTTLE RESPONSE.
Detailed instructions are included.
Installation is easy, as this is a direct OEM plug in unit & can
be installed in less than 5 mins, no cutting or splicing required.
The TRE has no effect at full throttle. It does have an effect at throttle openings
up to 1/2 in gears 1 through 4 at ANY rpm. It will disable the speed limiter on
the GSXR1000 and GSX1300R. The TRE does NOT affect full throttle power.
This has been verified on the dyno and on road under controlled conditions.
The TRE is designed for "race use only".
____________________
Available for the following:
'01-13 GSX-R600*
'98-13 GSX-R750*
'01-13 GSX-R1000*
'98-03 TL1000R/S
'03-08 SV1000/S
'03+ SV650/S
* * PLEASE NOTE * *
GEAR POSITION INDICATOR WILL BE DISABLED
WHEN SENDING PAYMENT, PLEASE LET ME KNOW
THE YEAR & MODEL OF BIKE YOU NEED IT FOR?
Also available to suit:
Hayabusa
GSX1400
M109R
Koupit lze třeba zde
1 reakcí na tento příspěvek tl 100 Tre timing retard eliminator
28.10.2014 v 12:02 | Nahoru | #2
A zkoušel si to
(reakce na) tl 100 Tre timing retard eliminator
28.10.2014 v 12:05 | Nahoru | #3
irmscher1000> já jo a rozdíl jsem nepoznal
28.10.2014 v 13:03 | Nahoru | #4
Takže blafofacka jen mě to zajímalo nějaké ty zkušenosti jsou lepší než technický manual
28.10.2014 v 14:25 | Nahoru | #5
Tady máš víc info
případně popros autora, ať Ti jeden udělá
Naposledy editováno 28.10.2014 14:25:50
Suzuki TL 1000 nereaguje na otočení... Suzuki TL 1000S irmscher1000 10 27.3.2024 v 18:24 irmscher1000
TL1000R/S zadní napínák rozvodu - k... Suzuki TL 1000S, Suzuki TL 1000R, Suzuki TL1000R Als... Wanislav 4 29.7.2023 v 19:16 assassin
výměna těsnění pod hlavou suzuki tl... Suzuki TL 1000S pavevyskocil 14 22.7.2023 v 12:01 Martin74
Suzuki TL 1000S nechce chytit Suzuki TL 1000S Martin74 14 1.5.2023 v 15:58 assassin
Hledá se mý bývalý Tele [1, 2] Suzuki TL 1000S, Suzuki TL 1000R dewwil 39 15.4.2023 v 19:21 dewwil
