Pokusili se tu upravit Air box při použití full exhaust systému od Zardu. Výsledky jsou zajímavé vzhledem k nákladnosti úpravy (samozřejmě když nepočítáme ty Zardy)
Vyřešili to tak, že seřízly vrchní kryt air boxu a tím ho víc otevřeli. Na zbytek mrkněte na detailnější popis a grafy...
http://www.bikeboy.org/sport1000zard.html
![Sport 1000 Zard](http://img.motofotky.cz/upload/images/forum/2013/08/137432_zard1.jpg)
![If you’ve had a look at the air filter setup on a Sport Classic you’ll know how restrictive the inlet is and that the filter itself isn’t much better. If you haven’t, see the photo below. That little square opening arrowed is the air inlet!](http://img.motofotky.cz/upload/images/forum/2013/08/137433_sport1000airbox1.jpg)
![The filter is a round style, probably 60mm diameter and 180 or so mm long (that’s a very rough guess, made sitting in the lounge room tapping away on the laptop several weeks after looking at the filter). Thinking about it now, I guess a single 60mm hole feeding a bike with 45mm throttle bodies isn’t that bad, and the airbox is quite large in volume. But the inlet is still much less flowing than an SS or Monster with an open lid. So I did the obvious thing and attacked the air filter lid with a cutoff wheel. (as you do), photo below.](http://img.motofotky.cz/upload/images/forum/2013/08/137434_sport1000airbox2.jpg)
![The next photo shows the little passage that passes for the std air inlet – it’s about 20 - 25mm square and stays that way for maybe 100mm before reaching the filter. After hacking the lid there’s a round hole about 60mm or so. So you’d expect it to help. It’s much easier to see once you’ve hacked the bit above the filter off.](http://img.motofotky.cz/upload/images/forum/2013/08/137436_sport1000airbox3.jpg)
![Graf](http://img.motofotky.cz/upload/images/forum/2013/08/137439_sp1g3.gif)
![](http://img.motofotky.cz/upload/images/forum/2013/08/137440_sp1g5.gif)
![](http://img.motofotky.cz/upload/images/forum/2013/08/137441_sp1g10.gif)
Naposledy editováno 23.02.2013 07:51:49
1 reakcí na tento příspěvek Tuning Air boxu Ducati Sport Classic
2 reakcí na tento příspěvek Tuning Air boxu Ducati Sport Classic
http://kaemna.de/cms...kel&artikel=2563
1 reakcí na tento příspěvek (reakce na) Tuning Air boxu Ducati Sport Classic
Ale jinak bych teda na sportce taky nic moc neseřezával, k tomu bajku mi honění koní moc nejde dohromady...
Je ale pravda, že mě tento test fakt svou jednoduchostí a nákladností překvapil.
viz.: http://images.bidor...ter-Carbon-Fiber.jpg
Já bych osobně šel do toho MWR, tedy to tady dával Horác pod označením Puretec.
Dělají to přímo i v provedení na Sporta buď jako vložku nebo přes celé víko:
http://www.racingair...rs.eu/?ids=kop3/sub5 (rolovat asi do půlky)
a u nás to prodává Polášek:
http://motocentrum.e...duchov%FD+filtr.html
Hlavně to vypadá, že to tam bude vždycky dobře uchycené, usazené, nebude to vibrovat apod.
![](http://motocentrum.eshop-zdarma.cz/shopy/motocentrum.eshop-zdarma.cz/zbozi/230/1304875862.jpg)
se mi líbí čím dál tím víc...
Takhle vypadá graf s tímto filtrem (je to sice na Hypermotard 1100, ale pro porovnání to stačí):
![](http://www.racingairfilters.eu/data/media/DP%20vs%20MC-020-05.jpg)
A cena u Pláška necelých 2,2tis je lepší než v DE (99 EUR).
Nemáte s tímto filtrem někdo praktické zkušenosti? Předpokládám, že se dá čistit - čím tedy a jak často? Že by se to dalo klasicky vyprat v saponátu jako staré molitanové vložky na croskách? Jaký bude hluk z airboxu?
Takže buď to risknout s originál mapou nebo se na to vyprdnout...
Horác píše: No právě, dávat 5tis. za nehrání nějakého softu do ECU se mi opravdu nechce...
To tam jen prehrajou předpřipravenou mapu? A co když máš ještě ne-termignoni laďák? Počítám, že potom to může bejt 5 tisíc splachnutejch, že?
Mě to ladění hrozně láká, ale právě se bojim, že do toho začnu vrtat a pak se nedoplatím a ještě to ani nebude lepší...
Další nové info: V případě nespokojenosti s mapou po instalaci (REXXER) u pana Poláška vše uvede do původního stavu a vše ZDARMA!!! Rozumí se tím, že nezaplatíš nic. Což je si myslím, férová nabídka.
Naposledy editováno 22.02.2013 08:24:19
![](http://www.racingairfilters.eu/data/media/Instalation%20MC-020-05%20%20%20%20%20Sport%20Classics&Hypermotard.jpg)
Koukal jsem na US fóra a tam to borci používají ať již se seriovým filtrem, tak i s K&N a jsou spokojení.
Nechal bych jich pár vypálit z hliníku...
Takhle to vypadá po montáži:
![](http://www.gerhartdesignstudio.com/FilterPlateInstalled1.jpg)
![](http://www.gerhartdesignstudio.com/FilterPlateInstalled2.jpg)
edit obrázek
Naposledy editováno 22.02.2013 09:18:45
brzda80 píše: Thiacomo> to je právě to, nemají samozřejmě mapy na všechny možné systémy výfuků. Nahrají tam co nejvíc podobnou tvému systému. Dle mě rozdíl v normálním provozu nepoznáš. Jde o to, že je to levnější varianta než racing Ducati performance ECU.
Jo tak to si to tam necham nahrát jen na okruh a pak řeknu, že nejsem spokojen :))
Pokud to nekdo planuje, tak k tomu doporucuju komplet laufy (bez katu) at to dejcha na obou stranach - a MUSI se premapovat ECU, ja mam treba komplet od Zardu kterej ma stejny/hodne podobny parametry jak termixy a s mapou na full termix to slape vyborne - takze pokud bude nejaka skladacka (koncovky a svody od ruznejch vyrobcu) tak pozor na to - Tfreedom by mohl vypravet
Pokud nenajdes na Rexxeru vhodnou mapu, tak nahrat jakoukoliv otevrenou a koupit PC a naladit na brzde....coz samo je ve finale nejlepsi volba, pokud jde o kazdyho konika.
Classický koutek [1 ... 9, 10] Ducati Sport 1000 | VlastíkPlamínek | 297 | 9.10.2020 v 21:10 Petr7474 |
Svody Ducati Sport 1000 | danny82 | 15 | 12.3.2014 v 18:27 danny82 |
Čerpadlo Ducati Sport1000 Ducati Sport 1000 | danny82 | 12 | 20.9.2013 v 13:35 danny82 |
Pneu pro Ducati Sport1000 Ducati Sport 1000 | danny82 | 14 | 20.9.2013 v 13:32 danny82 |
Kód chyby P0170 - Fuel Trim Malfunc... Ducati Paul Smart 1000, Ducati GT 1000, Ducati Sport... | Horác | 15 | 7.8.2013 v 19:02 Horác |
