1 reakcí na tento příspěvek ztrata klicu
Insert the red key into the ignition and turn it to "ON". The immobilizer indicator light should come on for 1 second and then go off.
With the red key still in the ignition, start the engine.
Shut off the engine and remove the red key. The immobilizer indicator light should start to blink after 30 seconds.
Insert the red key into the ignition and turn it to "ON", then "OFF" and then remove the key within 5 seconds.
Insert the black key into the ignition and turn it to "ON" within 5 seconds.
While the immobilizer indicator light is flashing, turn the black key to "OFF" and then remove the key.
Insert second key and turn on before immobiliser light stops flashing.
Wait for the immobilizer indicator light to stop flashing. It should stop 5 seconds after you remove the black key.
záběr spojky Yamaha FZ6 N | Dymus | 8 | 26.5.2024 v 17:13 kuzmič |
nastavení páky řazení - na lepidlo ... Yamaha FZ6 N | zero1724 | 2 | 23.10.2023 v 08:31 zero1724 |
Středový stojan na FZ6 Yamaha FZ6 Fazer, Yamaha FZ6 N, Yamaha FZ6 Fazer S2,... | matesh13 | 7 | 9.9.2023 v 21:06 _Michal |
Nádrž Yamaha FZ6 N | RTSbike | 10 | 30.7.2023 v 08:15 RTSbike |
Oprava moto [1, 2] Yamaha FZ6 N | RTSbike | 52 | 24.7.2023 v 14:43 smap |
