Naposledy editováno 25.05.2023 20:58:15
Your post translation into Czech is a bit off obviously. Responses translated back into your language will be off even more, possibly misleading.
Why are you even posting that on local national board? International motorcycle forums are plentiful. Or are you using a bot to make this post literally everywhere?
Naposledy editováno 23.05.2023 17:56:11
1 reakcí na tento příspěvek Skutečné náklady na nákup motocyklu
The maintenance is similar to car's, of course there is no AC etc., on the other hand you need to clean and oil the chain and usually the intervals are shorter. You also need to buy gear, even if nothing was mandatory in your country, it is still advisable to get some gear in case you crash.
Údržba je podobná ako v aute, samozrejme, nemáš klimatizáciu atď., na druhej strane je potrebné čistiť a mazať reťaz a intervaly sú zvyčajne kratšie. Okrem toho si musíš kúpiť výbavu, aj keby v Tvojej krajine nebolo nič povinné, aj tak by som si zohnal niečo pre prípad havárie.
