https://www.ebay.de/...c:g:FY8AAOSwotNZ5J-8
edit: spatny link...
https://www.cmsnl.co...411078/#.W7s2ij_8I-U
Naposledy editováno 08.10.2018 12:52:36
tady můžeš číst : https://advrider.co...r-shaft-test.555264/
konkrétně tenhle příspěvek:
On the 1995 and earlier KLR650's, you'll have the multi-piece balancer sprockets. These can fail. Since the left side front balancer sprocket is what drive the shaft, you might have an issue. You can replace the sprockets with the one piece parts from the 1996 and later. You'd need the front sprocket, rear sprocket, and one washer. I can't remember for sure, but I think it's the inner washer shown on the later model parts fice. Compare the early and late to get the part numbers (buykawasaki.com) In your engine you'll see 4 springs and pins (if they are still in place) in each of the left side sprockets. Sometimes the pins and/or springs are missing, and sometimes the Sprockets breaks where the pins drive. Here's a pic of good and bad parts from the early engine. This can result in a ruined engine. New parts are pricey. Get the used stuff if you can.
Naposledy editováno 08.10.2018 19:37:41
Zpřevodování KLR 650c Kawasaki KLR 650 | KubAiS | 6 | 19.2.2024 v 21:27 KubAiS |
Montáž blastrů - plná, zaslepená ří... Kawasaki KLR 650 | KubAiS | 8 | 19.2.2024 v 20:44 Slávek-TDM |
Díra v plechové nádrži skrz Kawasaki KLR 650 | KubAiS | 11 | 16.5.2023 v 20:13 Julip2 |
výfuk Leo Vince x3 na čtyřkolku Suzuki DR 650, KTM LC4 640, Kawasaki KLR 650, Suzuki... | Perkz | 2 | 24.10.2022 v 14:02 Eddie83 |
Ventilátor běží pořád Kawasaki KLR ... Kawasaki KLR 650 | Sasori23 | 13 | 20.7.2022 v 10:17 Anti |
