Naposledy editováno 12.05.2017 00:39:50
DIAGNOSIS
This menu interfaces with the systems fitted to the
motorcycle to carry out diagnosis. To enable the menu, a
password is needed that is available only to aprilia service
centres.
• Insert the service code
It is a 5 digit code, for Pegaso the code is: 25973
If code is wrong, appears the message:
• Incorrect code
The instrument panel goes back to main menu; if not, the
menu appears:
• EXIT
• ECU ACTUATIONS
• ECU PARAMETERS
• ECU ERRORS
• DASHBOARD ERRORS
• DELETE ERRORS
• SERVICE RESET
• DISCONNECT
• UPDATE
• UPDATE KEYS
• KM / MILES
Once the operation is over, the instrument panel goes back
to main menu.
Kterou motorku vybrat [1, 2, 3] Aprilia Pegaso 650 Trail, Yamaha XT 660 Z Tenere | Sportback | 65 | 22.3.2021 v 10:52 Slávek-TDM |
Uprava laufu. Aprilia Pegaso 650 Trail | vladaobi | 6 | 18.1.2021 v 15:33 FiZzeR |
Tachometr Aprilia 650 trail Aprilia Pegaso 650 Trail | Fira528 | 1 | 8.3.2020 v 05:45 krokoš |
Divné cukání a chod motoru Aprilia Pegaso 650 Trail, Aprilia Pegaso 650 Strada,... | oskaradam | 8 | 2.9.2019 v 23:11 jenda-pegaso |
SOS nesprávný kod Aprilia pegaso 65... [1, 2] Aprilia Pegaso 650 Trail | vladaobi | 43 | 31.8.2019 v 20:30 -PePe- |
