Téma: Ignition coil Vape z95
2.4.2014 v 18:19
Hello i'm looking for an ignition coil for bxm 125
a vape z95 or compatible model
thank's
2.4.2014 v 18:36 | Nahoru | #1
Tož jsem nějaký opožděný, ale to nás ti Amíci už obsadili, že se tu píše anglicky?
2.4.2014 v 18:45 | Nahoru | #2
Já jsem francouzsky
2.4.2014 v 18:45 | Nahoru | #3
No a co?
2.4.2014 v 18:55 | Nahoru | #4
Nic, jen, že tady jsi v česku.
Naposledy editováno 02.04.2014 18:55:20
2.4.2014 v 18:59 | Nahoru | #5
Hi, I can recommend you only one thing. Click on this link . There you should write your name in the colum "Jméno", in the next colum your telephone number a in the last colum your e-mail addres. I think, you can write to Blata company about your problem in English. It takes them about 2-3 days to answer you.
I have 2 Blata motorbikes as well, but I am not at home now. I am not sure if I have this ignition coil or I have another. I'll send you a message on Friday with more information
2.4.2014 v 18:59 | Nahoru | #6
2.4.2014 v 18:59 | Nahoru | #7
no help for riders here?
2.4.2014 v 19:00 | Nahoru | #8
thank's
1 reakcí na tento příspěvek Ignition coil Vape z95
2.4.2014 v 19:01 | Nahoru | #9
Thank's 125Mare k
(reakce na) Ignition coil Vape z95
2.4.2014 v 19:09 | Nahoru | #10
lopluioou> Your welcome I have had many problems with this motorbikes, so I know your feeling
3.4.2014 v 11:06 | Nahoru | #11
I made a call to VAPE and they told me, that they have Z95 in stock. Only not on the e-shop.
Price is cca 25€ + postage.
You can make an order thru email petra.vilimkova@vape.cz or by phone +420 573 344 786
Sorry for my bad english
3.4.2014 v 13:58 | Nahoru | #12
seikos>
great!!!! thank's a lot
18.4.2014 v 18:18 | Nahoru | #13
HI,
i have received my new ignition coil vape Z 95
But no spark anymore ARG
i don't understand where the problem come from ?
18.4.2014 v 20:56 | Nahoru | #14
lopluioou> You have the ingnition by Vape . I have it as well a there is one problem with ingnition coil but not in the induction coil but in the coil in the left side of your engine block.
You can check it with your multimetr. Look at the electrical cabels from the left side of the enegine block. There is one white connector under the fuel tank. In this connector come 3 colourful cables - white, red and the yellow one. Open this connector, take your multimetr and measure the rezistance between this cabels.
Between - white and red 620Ω +- 10 (max)
- red and yellow 205Ω +-10 (max)
If you have another results, you have problem with the all ignition You can´t repaire it at home. So take down this part of engine block, take it in the box a send it to Blata company. They repaire it and send you it back
Here you have some photos to inspiration Good luck
18.4.2014 v 20:58 | Nahoru | #15
white-red 620 Ohms +-10 (max)
yellow-red 205 Ohms +-10 (max)
18.4.2014 v 21:41 | Nahoru | #16
Great ! Thank's
1 another question :
I have oil in the stator carter it's normal ?
You save my life
19.4.2014 v 12:36 | Nahoru | #17
lopluioou> Your welcome The oil is normal, because everywhere in the block of engine is oil.
If you sent carter to Blata company, ask them for a paper gasket between carters. In stead of the paper you can use cement (I dont know, what is this . Do you see, what I mean? But paper is better
Is you rezistance different? Can you tell me your results? Only for check
19.4.2014 v 14:46 | Nahoru | #18
Ok thank's
Oil on the stator is normal it means?
I have 0.63 on yellow/red
0.43 on white/red
On omhs 20k position
Thank's
19.4.2014 v 15:52 | Nahoru | #19
lopluioou> Yes, it is Almost each bike has the system It isnt unusuall In the link with stator photos you can see that the coils are covered by oil
Thaks for results. now you know where the problem is and you can it repaire. Blata has a new type of stator. The last type (you have it) has this defect each +- 8000 km. I have a new one and they said us, it should be better. We hope
20.4.2014 v 10:16 | Nahoru | #20
Ok cool !!!
You think i can buy it to VAPE ?
I don't have see it on the vape's online shop
But maybe they have it in stock...
It's VAPE a67s-8 but new model ?
Thank's a lot
20.4.2014 v 11:14 | Nahoru | #21
lopluioou> No, you can´t it buy by Vape, only by Blata company. They change all the stator with all coins on it and they send it to you back
So you should write an e-mail in the internet pages of Blata company . Tell them about your problems about your reults of rezistance a send them your carter with stator. They change it and send you it back. When was made your Blata?
If is older than 2 years you must pay new stator and the other thigs (postage) and so on The new stator costs about 1500 Kč (about 50 Euro).
This type of ignition is not avaible on Vape pages, because the make this ignition only for Blata company
21.4.2014 v 17:35 | Nahoru | #22
Hi thank's,
It's a bxm 125 2010
I have already write a mail to blata for a neutral contactor 3 weeks ago
But i don't have receive an aswer ....
Maybe they don't understand english?
21.4.2014 v 20:55 | Nahoru | #23
lopluioou> I hope so in a few day I try to have a contact with them. So I´ll tell them about your problems a they are going to solve it
21.4.2014 v 21:17 | Nahoru | #24
Many thank's
22.4.2014 v 09:09 | Nahoru | #25
Hi,
I received an aswer this morning from Blata
Thank's
22.4.2014 v 10:32 | Nahoru | #26
lopluioou> But I didnt write them
22.4.2014 v 19:11 | Nahoru | #27
No it's me
13.5.2014 v 18:40 | Nahoru | #28
lop
Hi ! i have received my new stator today
I have a big spark on the spark plug
But arg the blata don't start ...
13.5.2014 v 21:52 | Nahoru | #29
Ou So that´s a real problem Now I dont know, what to do Have you been to a motorbike mechanic? I normal case, you have solved the problem.
14.5.2014 v 21:43 | Nahoru | #30
125Marek>
Hi marek thank you very very much !
Finelly she start tonight !
Yesssssss☺
Problém po zimě Blata BXM 125 Panturis 2 20.3.2023 v 21:18 Slávek-TDM
Blata 125 průměr podtlakového venti... Blata 125 Enduro, Blata 125 Motard, Blata BXM 125 vondris6 0 18.3.2023 v 22:19 vondris6
Blata BXM Blata BXM 125 Panturis 4 16.10.2022 v 05:38 HornisGSX
Blata Blata 125 Enduro, Blata 125 Motard, Blata BXM 125 Panturis 0 3.10.2022 v 10:07 Panturis
Blata 125 BXM (původ motoru) Blata 125 Enduro, Blata 125 Motard, Blata BXM 125 Panturis 2 21.8.2022 v 12:14 Ariete
